Make Preferences search work with English even when using other langauges
Right now, the Settings search in Directory Opus only matches what’s shown in the current UI language.In practice, this works fine for casual use, but once you start using documentation, forum posts, or scripting references, things start to feel a bit disconnected.
If your UI is in a non-English language, you can only search using that language’s terms. Most official docs, forum answers, and scripting examples use English terminology.
So users often end up doing this small but annoying loop:
read English guide → find term → guess translation → search in UI → hope it matches.
Some UI translations are slightly different from the original concept, and sometimes multiple English terms map to similar localized labels.
I think the Settings search could feel a lot more natural if it didn’t care so much about the current UI language.Allow searching with English terms even when the UI is not in English.Settings search should be decoupled from localization layer and bound to canonical feature identifiers.
A toggle that prioritizes canonical feature names and internal identifiers would be very useful for power users.It would make it much easier to move between documentation, forum advice, and actual settings without constantly translating terms in your head (or in your GPT).
Thanks for considering this suggestion. I really appreciate the continued improvements to Directory Opus.
Support this!
It would be even better if we could jump directly to an option from its path and have it highlighted.
For example, for the path "Preferences / Viewer / Standalone Viewer / High quality scaling", the page path is "Preferences / Viewer / Standalone Viewer", and the option name is "High quality scaling".
It would be great if you could paste the whole path into the search box and jump directly to it with the option highlighted, just like when you search for "High quality scaling".
EDIT:
Oops, I just realized that if I could search in English, I could just search for 'High quality scaling' directly, this makes it a bit complicated. Please just ignore this :sweat_smile:
This is a good idea, but it's unfortunately not fully possible currently. The search index is built from the actual Preferences pages (which are created on-the-fly) and the pages are only built in the current UI language.
In the next beta we've made it so the original English-language names of the individual pages are included in the index (so you can, e.g. search for "standalone viewer" even when not running in English). But at the moment you still can't search for individual controls in anything other than the currently selected language.
