Manual sort (xp auto arrange)
hi
in Explorer window i can move files or folders position in view regardless of sort by option...but in Opus it seems to be locked ??
also another question in large icon view how can i hide file extension ?
thanx
At the moment Opus always sorts the list of files. There's no way (at the moment) to arbitrarily re-order files, except by renaming them (or changing some other attribute that's being sorted by).
No way that I know of. In Folder Options there is a checkbox to "hide file extension in filename column" but this only affects Details and Power modes, not Large Icons. (I guess that isn't strictly a bug as, technically, Large Icons mode doesn't have a filename column, but maybe the checkbox should still apply. I'll file a feature request along those lines.)
thank u man... :slight_smile:
