I would like to know if I can color code directories manually so this way I can decide which folders to look for when I do this. It would make it a lot easier for me to set it this way. For example, when I have a lot of folders...instead of sorting by name, date or timestamp...it would be great to just click the folder and color it differently. Can this be done?
Try searching the forums or reading the manual. A simple search found this ["set foldor colour" context menu option?).
