Is it possible to mark more than one reply?
For example, I posted a thread and received three replies, and I want to mark two of them as solutions because both included different answers and both are correct and valid.
You can't; the forum software doesn't allow it.
If you mean this thread - New folder with items ... I want to be able to give it a name - #12 by KebordKauboi - then you should only ask one question per thread, so it shouldn't be needed in any case. ![]()
Ok.
Yes, it is.
Ok.
Thanks ![]()
Lesson learned ![]()
