If you're using Opus 10 and want to export this plugin to USB, make sure you've got the latest version. This was put out in February, before Opus 10 was released, and I forgot to mention it until now.
Version 1.0.0.6 (18th February 2011):
- Update to enable the plugin to support USB export with Opus 10.
Version 1.0.0.5 (3rd August 2009):
- Small internal change. Unlikely to make a difference but update if you feel like it.
Version 1.0.0.4 (21st May 2009):
- Potential speed-up when viewing files flagged as "slow." (Probably only affects files passed to the plugin from an FTP site.)
Version 1.0.0.3 (29th August 2008):
- Images with 16-bits per sample now have the right depths reported back to Opus.
Version 1.0.0.2 (29th August 2008):
