Mcafee right click, scan menu
When I right click a file and the right click menu appears. If I click Mcafee scan it does nothing however if I have Malawarebytes installed and click on Malawarebytes menu scan that scans. So why does Mcafee right click not work in directory opus 13. It started to work in Directory opus 12 (last few versions). Any ideas on how to get this to work in version 13?
Last time we looked, McAfee hid their context menu from everything except explorer.exe; is that no longer the case, or have you added a custom entry for it in the past?
In the last couple of version 12 updates it started working for some reason. I did try another file manager and it worked ok so it has to be something directory opus is doing differently. If you can't get it to work is there a way to create a button that can do this instead.
AFAIK it’s not something that changed on our side (in 12 or 13).
We’ll make note to look at it, but won’t be able to for a while as we need to get the release ready at the moment.
