I have been trying to tidy up my pictures collection stored in various folders/subfolders historically taken by different mobiles with the same brand and/or different brands.
When I am trying to merge the folders , there are hundreds of different pictures files with the same name but different content.
Example:
Xperia Z
--Pictures
Xperia Z5
--Pictures
For my archives , both old and new files (with the same name) are important and to kept, not overwritten. According to the standard dialog box which comes up in Dpous, I can either skip or overwrite, but there is no way to keep both the files in the same folder.
So I am asking is there is a plugin/script which compares the filenames and gives an option to rename either of the files if both files are not exact replica of each others.
If you copy folder over folder with the same name with files with the same names inside, you should have option "Rename New" (and "Rename New All") while you holding CTRL (or CTRL+SHIFT) on Confirm File Replace dialog window.
The dialog gives you all these options (plus more inside the Skip button-menu):
As PeterB says, you can hold the keys shown in the menu (Shift, Ctrl, etc.) to get quick access to the commands from the main button, without having to open and select from the menu.
Thanks for the guidance. Just one more related query , while using the "Rename new (All)" or "Rename Old (All)" , we see that opus adds a suffix (1)..n to the same matching filenames with different contents.
Is there a way to control or define our own prefix or suffix, for example if I chose to rename old, I would like to add prefix or suffix "_old" to such files or "_old(1...n)".
Rename Old adds " (original)" to the name. It's only Rename New which adds a number (unless there's already a file with the specified name).
There isn't a way to change those at the moment, other than manually typing a different name for the files (which the Replace dialog also allows), or doing the copy/move with a custom script.
New name:
{datetaken|D#yyyy}\{datetaken|D#yyyy-MM-dd}\* {datetaken|D#yyyy-MM-dd T#HH.mm.ss} {cameramodel}
It really depends on your preferences and the quality of your pictures' metadata. I personally use a folder structure like in the example above and rename pictures from mobile devices simply to "yyyy-MM-dd HH.mm.ss" plus any special suffix like PANO. Pictures from "real" cameras keep their original name like DSC12345 plus a padding digit.
Digging an old thread , just exactly after 1 year (+ 2 days).
So I was able to experiment with the rename command to tailor a renaming mask for my existing photos. Thanks to @lxp in his reply above.
However I was searching if I can only apply such renaming mask selectively when copying one folder contents over the other.
As mentioned by @Leo above , when DO sees a duplicate file name it gives the "Confirm File Replace" dialog box with selected options (as can be seen in the screenshot)
In the "Replace" sub menu there are only limited options to play with either newer or older file which would simply add a prefix of "(1)" after the file name.
Is it possible that within replace submenu, I can specifiy DO to:
First calculate the MD5 for both files, just be sure that two files with "same name" actually have different content.
If MD5 is "not" equal then apply an advanced file renaming mask preset - from rename command options. i have saved a preset as below screenshot.
Without scripting, you'd have to do it in two steps, unless you want everything to be structured like in your rename preset (in which case you could do everything via the rename dialog/command instead, since it can move files as well).
Doing it in two steps could involve running the duplicate finder after the copy, and then searching for any remaining * (1).jpg or similar files and applying the rename to them.
Note that the Replace dialog highlights size, date and description differences in bold, and has an option to skip things where the size and date are identical. That's often enough to know if a file is actually different, unless there's a workflow which makes changes but preserves the old file dates and does not change the file sizes. (With JPEGs, that'd probably be where unless only the metadata was edited and the editing tool was configured to preserve the date.)
With scripting, you could split the files into ones which exist and don't exist already, copy/move the ones that don't exist normally, and then apply a rename to the ones that do exist and have different contents. That'd be more work to set up though.
