DO9 would minimize to a tray icon - now it will only minimize to the app bar. How do I do this in DO 10?
Also note to powers that be: if "minimize to tray" was located in the help menu - my answer would already be found.
Opus doesn't have a minimize to tray feature.
You can add a tray icon, and set it so double-clicking it opens an Opus window, and then simply close the Opus window for a similar effect. (Assuming you have Opus set to remember/restore the last-used window.)
One question leo, is it possible to disable the tray icon? I don't use it and I have disabled the startup with Windows feature so it is useless for me.
Yes, turn off Add icon to the Taskbar Status Area in Prefs - Misc. - Windows Integration.
Thank you
