Missing Box Drive menu in right button option
hello, i'm using the 12.2 version and also Box Drive to sync folders/files.
Under the windows explorer there is a menu for Box Drive options (see below) but under Directory Opus, impossible to have which is a pain.
Could you help to solve this issue ?
Thanks
Are you really using 12.2, or 12.20?
Sorry for the confusion : it is 12.20
Please try selecting Preferences / Folders / Virtual Folders / Treat all "virtual filesystem folders" as virtual and close and re-open any tabs which are showing the Box folder. It should then work.
2020-04-06 20-43-31 Clipboard Image
Thanks, just tried. "virtual filesystem fodlers" was already treated as virtual. I removed, applied, re-select and applied but still no menu of Box drive.
Any clue ?
Could you post a screenshot of what you see in Opus when right-clicking something in the Box folder?
Hello Leo, here we are
I need to see the folder itself, uncropped. From what I can see, it isn't the virtual folder, but I can't see much of it.
Try the actual Box folder, not a subfolder, too, please.
Is it what you are looking for ?
I also have shortcuts of the Box Folder above.
This is the Box Fodler
Here we are
Leo wanted to see the Box folder.
Not easy to understand what you need; I assume tis one is the right one.
Thanks, that last screenshot is what I wanted.
From the way the file display is drawn, that's definitely Box itself drawing the file display there. I'd also expect the right-click menu to have all the desired items in there if you right-click something.
Are the menu items only missing if you're in a folder below the Box folder, and not in the Box folder itself?
