Hello,
"Create function from current settings" creates a button without the xml button code.
Directory Opus 13.23.5 (Beta) Build 9489 x64
OS 10.0 (B:26200 P:2 T:1) SP 0.0
Thanks.
That's all it's supposed to do.
It gives you the command, not a whole toolbar button.
(You may not want to use it on a toolbar. It'd be a pain to have to paste to a toolbar just to get the command and delete the button and then put the command into a context menu or script, for example.)
And why is a non functional .dcf file created when I use the context menu to insert it into the file view?
We've fixed that for the next update.
