.mkv - open imdb site
onedot3, It's real easy to use this. Your MKV or any other video file should be in its own folder. Inside that folder just create a .url file that links to any site.
This is real useful. I also made a second script, so you can select the parent folders and it does the same thing. This one is for folders. I use both scripts.
function OnClick(clickData)
	DOpus.ClearOutput();
	cmd.deselect = false; // Prevent automatic deselection
	if (clickData.func.sourcetab.selected.count == 0)
		DOpus.Output("  (none)");
	else
		for (var eFile = new Enumerator(clickData.func.sourcetab.selected_dirs); !eFile.atEnd(); eFile.moveNext())
			var sDir = eFile.item();
			var eSel = DOpus.FSUtil.ReadDir(sDir);
			var eItem;
			var file;
			var fileext;
			while (eSel.complete == false)
				eItem = eSel.Next();
				file = eItem.RealPath;
				fileext = eItem.ext;
				DOpus.Output(file);
				if (fileext == ".url")
					DOpus.Output("^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^");
					cmd.RunCommand(file);
			DOpus.Output("-----------------------------------------------------------------------------------");
