MKVs Beginning with Hash Tags Missing Metadata
You can create a list of currently shown columns that can easily be shared with
ClipCopy COLUMNS
Thank you, but that doesn't relate to or solve the issue.
So the files aren't even being opened?
I don't understand what you mean by the files not "being opened". They all work properly. It's just they don't display video and audio bitrate metadata in Opus's columns.
Process Monitor logs tell you when and what files are being opened ...
Analyzing them can help understand what happens
Send us the Process Monitor logs and we can look at them.
The best thing to do is have a folder with two files, one that works and one that doesn't, then go into it while logging, so we can see what happens for each file.
If needed, and so you don't have to find it in all the old posts above: Process Monitor instructions (in particular, be sure to use the PML format when saving the log).
