How to change the color on hover over a folder
Thank you
Thank you
The hover colour comes from the Windows theme and isn't configurable in Opus.
Thank you for this quick response
is there a way to get around this by going through something else
If you turn off Preferences / Display / Options / Use visual styles to draw items it will disable the hover colour altogether.
Perfect thank you Jon
If you turn off Preferences / Display / Options / Visual styles override file selection colors, you can keep visual styles on and still have a hover color, which then comes from your choice of file selection background color.
Where is the " file selection background color" mentioned above?
