Modifying images in viewer
Hey all,
I hope you can help me out. I know how you can view an image in the built in dopus viewer and choose edit to "modify" the image's gamma range. But is there anyway to then save those corrections to that current image that is open (basically overwrite it with the new modified image)?
No, the gamma correction applies to the current display only.
You can use the Convert Image function to rotate, resize, etc, but that's it. Opus is not an image editor.
may be of help:
with the PNG toolbar
you can change gamma of a PNG file.
[PNG Toolbar)
Hey cool. Thanks a lot guys. I'll download and try the png toolbar.
