[quote="Mou-Di"]Thank you for your answer. This helps allready for my first needs.
To have a more flexible System it would be helpful to mark in the right panel all the folders as target and then in the left panel the file I wanna copy. With an option/button "copy to all marked folders" I could save so much time![/quote]
BTW. I think my method (copy from one single lister source to all other opened single listers) is more flexible - you can copy to different drives too, not just to different folders. My procedure is not perfect, but works that way:
VBScript for button:
Option Explicit
Dim t, lister, veve, sourx, ndest, xx, doCmd, cmd, tab, selItem, folderEnum, folderItem, lstsourc
dim destix(1000)
lstsourc=""
ndest=0
For Each lister In DOpus.listers
if lister.dual=0 then
if lister.state=1 then
sourx=lister.activetab.path
else
ndest=ndest+1
destix(ndest)=lister.activetab.path
end if
end if
Next
DOpus.ClearOutput
Set cmd = clickData.func.command
cmd.deselect = false
If clickData.func.sourcetab.selected.count > 0 and ndest>0 Then
cmd.Clear
For Each selItem in clickData.func.sourcetab.selected
if lstsourc<>"" then lstsourc=lstsourc&" "
lstsourc=lstsourc&chr(34)&selItem.RealPath&chr(34)
Next
For t=1 to ndest
if sourx<>destix(t) then
cmd.SetModifier "async"
cmd.RunCommand "copy QUEUE=copytoallx,quiet "&lstsourc&" TO="&chr(34)&destix(t)&chr(34)
end if
Next
End If
end function
What is missing:
Check if lister is single.
Check if there is no repeated the same destinations.
I understand that, that's why I write that is alternative for single listers mode. I think you can write your procedure to copy into all other tabs instead of selected folders and there will be real solution for dual lister with different paths.
The script I posted for Mou-Di literally does exactly what he asked for. You can do lots of other things, but they aren't what he asked for, so it isn't what was written.
