Hi guys,
I want to home from work but I need to copy a load of newly rendered images from the server to my local hard drive.
The images take about 1 minute each to render and are approx. 7Mb in size. If I go home now, I will arrive in work tomorrow morning and manually move the files from the server to my hard disk. This will take ages and waste valuable working time.
Is there a way to select all files, move them to my desired folder, wait, for example 5 minutes, and then repeat the command until all the rendered have moved...?
The other issue here is that the server is slowly running out of space and if I leave them to render overnight, the server will soon be full and the rendering will stop.
Any thoughts please�
Regards
Roly
