Movie Specific Column Enabling
I have a folder full of divx 6 encoded videos, and if i enable any of the movie specific columns, none of them display any information. I have looked at the files using gspot and gspot tells me the codec is installed for the file. The file plays fine, I'm just looking to list the video file information in the columns...Any Ideas? (DOPUS 9.1.3, XPSP3)
What's the file extension? If it's not one of the standard ones you may have to enable it - see [HOW TO: Enable/fix playback of various media formats in Opus) for details.
Thanks, it solved my issue....
