I can't copy files from mtp devices to Desktop.
This is obviously a problem with DO.
I can copy to other folders, but not to the Desktop.
@Leo
Are you copying to the Windows desktop outside of Opus, or the desktop folder within Opus?
How is the copy being performed?
Have you tried doing the same thing in File Explorer?
How does it fail? Is there an error message?
(I'd still recommend using FTP or SFTP instead of MTP in almost all situations, as Hardkorn suggests.)
copying to the desktop folder within opus is ok.
If copying ot the windows desktop outside of opus,only able to create shortcuts.
Copying to the Windows desktop will be more complicated, because File Explorer is what handles most the copy operation in that case.
