Is there a way to select many images in a detail view list and rotate them using the Rotate right or Left arrow that appears above a Viewer Pain Window. I can do one at a time but when I select more than one using the mouse control select it only will do one.\ at a time.
Bob
You can run a command like this on your selected files, which should convert them all:
Image ROTATE=270 HERE REPLACE PRESERVEDATE (rotate left)
or
Image ROTATE=90 HERE REPLACE PRESERVEDATE (rotate right).
Thanks. I did also find a set of buttons on the image tool bar. Thanks for the quick response.
Bob
Yes, i think those buttons on the default "images" toolbar do quite the same, although they might miss the PRESERVEDATE part.
You can find some more examples of how to use the Image Convert command here:
http://www.gpsoft.com.au/help/opus11/index.html#!Documents/Automated_image_conversion_tasks.htm
abr- I forgot about that, you're right date preservation is extremely important thank you.
Bob
