Yep, unit test goodies for your DOpus scripts, ready to copy-paste into your scripts, ideally used with a decent editor e.g. VSC or alike, so you can fully enjoy JSDoc support. There are comprehensive examples below. I had this in mind quite a while, finally found some time today.
// quick start
var mut = new MUT({
name: 'My test suite',
abortOnErrors: true,
autoFlush: true,
skipSuccess: false
mut.addTest('my test', function () {
mut.assertEquals(somearr.length, 1, 'somearr.length == 1?');
mut.run();
Future version of this script will be hosted at my github.
* MUT: Mini Unit Tests
* @description
* JScript hates tiny puppies, so this class can fix some of that via Unit Tests.
* I am a huge fan of unit tests, and trying to get away from pure JScript development to TS transpiling,
* as I originally intended but since I have to maintain some gigantic scripts until I can rewrite them,
* I had to have a bit more help, so this little helper.
* MTU follows the industry standard process:
* * initialization via `var mut = new MUT({...})`
* * an optional `mut.setup()` callback before every test
* * multiple tests added via `mut.addTest(...)`
* * an optional `mut.teardown()` callback after every test
* * `mut.run()` to execute all tests
* @param {{name: string, abortOnErrors?: boolean, autoFlush?: boolean, skipSuccess?: boolean, cbOut?: function}} options
* can have the following keys:
* * `name`: test suite name
* * `abortOnErrors`: aborts as soon as any assertion fails
* * `autoFlush`: flushes the messages after each assertion
* * `skipSuccess`: success messages are not output or added to buffer
* * `cbOut`: callback function for custom assertion handling (assertion failures cannot be supressed!)
* the `cbOut`callback receives 2 parameters:
* * `msg`: string
* * `status`: boolean
* where status is true for assertion success, false for failure and undefined for plain messages (e.g. for internal messages)
* see below for example
* *Note:* `.flush()` method is effective only within `.addTest()` methods, not outside
* @example
* ```javascript
var mut = new MUT({
autoFlush: true
mut.setSetup(function() {
// DOpus.output('set up test environment');
mut.setTeardown(function() {
// DOpus.output('teardown test environment');
mut.addTest('assertEquals() calls', function () {
mut.assertEquals(0, 0, 'assertEquals number');
mut.addTest('assertNotEquals() calls', function () {
mut.assertNotEquals(undefined, null, 'assertNotEquals undefined');
mut.addTest('assertTypeofEquals', function () {
mut.assertTypeofEquals(true, 'boolean', 'assertTypeofEquals boolean');
mut.addTest('assertTypeofNotEquals', function() {
mut.assertTypeofNotEquals(function () { }, 'boolean', 'assertTypeofNotEquals function');
mut.run();
* if you want to collect the messages first so you can filter them out with own logic
* set both autoFlush & skipSuccess to FALSE, and pass a null function as callback
* and do NOT call flush in any of the addTest() methods
* @example
* ```javascript
var mut2 = new MUT({
name: 'custom collect',
autoFlush: false,
skipSuccess: false,
cbOut: function () { }
mut2.addTest('my test', function () {
mut2.assertEquals(1, 1, 'my msg');
mut2.run();
DOpus.output('mut2 messages:\n' + JSON.stringify(mut2.getMessages(), null, 4));
* example for custom callback:
* @example
* ```javascript
var mut3 = new MUT({
autoFlush: true,
cbOut: function(msg, status) {
DOpus.output((msg !== undefined ? 'msg prefix: ' + msg : '') + (status !== undefined ? ', status: ' + status : ''));
* @requires sprintf because f..k me if I cannot have at least one nice thing!
* @copyright
* see {@link https://hexmen.com/js/sprintf.js} and {@link https://hexmen.com/blog/2007/03/14/printf-sprintf/}.
* You should use the version supplied with this script if you do not want to adjust it to JScript yourself.
* I may or may not add some .assertXYZ syntactic sugar methods in the future, e.g. .assertNotUndefined()...
* **DISCLAIMER: I do not accept any liability, responsibility, whateverbility, you are on your own!**
* @license Creative Commons Attribution-ShareAlike 4.0 International (CC BY-SA 4.0)
* @copyright © 2024 cuneytyilmaz.com
* **Future version of this script will be hosted at my github: {@link https://github.com/cy-gh/}**
function MUT(options) {
if (typeof options !== 'object') {
throw new Error('parameters must be passed as an object');
this.getOutLine = function (/** @type {string} */ msg, /** @type {boolean} */ status) {
// non-fancy
// return 'status: ' + status + ', message: ' + msg;
// fancy
return sprintf('<b><font color="%s">%s</font></b>', (status === true ? '#33ff00' : status === false ? '#ff6666' : '#cccccc'), msg||'');
this.stdOut = function (/** @type {string} */ msg, /** @type {boolean} */ status) {
DOpus.output(this.getOutLine(msg, status));
this.name = (typeof options.name === 'string' ? options.name : 'mut');
this.prefix = this.name ? this.name + ': ' : '';
this.abortOnErrors = typeof options.abortOnErrors === 'boolean' ? options.abortOnErrors : true;
this.autoFlush = typeof options.autoFlush === 'boolean' ? options.autoFlush : true;
this.skipSuccess = typeof options.skipSuccess === 'boolean' ? options.skipSuccess : true;
this.$out = typeof options.cbOut === 'function' ? options.cbOut : this.stdOut;
this.tests = [];
this.setup = null;
this.teardown = null;
this.messages = [];
MUT.prototype = {
collectOrOutputOrAbort: function (/** @type {string} */ msg, /** @type {boolean} */ status) {
if (this.skipSuccess) return;
if (this.autoFlush) {
this.$out(this.prefix + msg, status);
} else {
this.messages.push({ 'status': status, 'msg': this.prefix + msg });
if (status === false && this.abortOnErrors) {
if (!this.autoFlush) this.flush();
throw new Error(msg);
fail: function (/** @type {string} */ msg) {
throw new Error(msg + '\n');
getMessages: function () {
return this.messages;
flush: function () {
var out = '';
if (this.messages.length) {
out += '\n';
for (var i = 0; i < this.messages.length; i++) {
var item = this.messages[i];
out += this.getOutLine(item.msg, item.status) + '\n';
this.$out(out, true);
this.messages = [];
addTest: function(/** @type {string} */ name, /** @type {function} */ fnTester) {
this.tests.push({ name: name, tester: fnTester });
setSetup: function(/** @type {function} */ fnSetup) {
this.setup = fnSetup;
setTeardown: function(/** @type {function} */ fnTeardown) {
this.teardown = fnTeardown;
assertEquals: function (/** @type {any} */ act, /** @type {any} */ exp, /** @type {string} */ msg) {
var _status = act === exp;
var _msg = sprintf('%s%s %s - act=%s, exp=%s', (msg ? msg + ' -- ' : ''), 'assertEquals', (_status ? 'ok' : 'err'), act, exp);
this.collectOrOutputOrAbort(_msg, _status);
assertNotEquals: function (/** @type {any} */ act, /** @type {any} */ exp, /** @type {string} */ msg) {
var _status = act !== exp;
var _msg = sprintf('%s%s %s - act=%s, exp!=%s', (msg ? msg + ' -- ' : ''), 'assertNotEquals', (_status ? 'ok' : 'err'), act, exp);
assertTypeofEquals: function (/** @type {any} */ act, /** @type {string} */ exp, /** @type {string} */ msg) {
var _status = typeof act === exp;
var _msg = sprintf('%s%s %s - act=%s, exp=%s', (msg ? msg + ' -- ' : ''), 'assertTypeofEquals', (_status ? 'ok' : 'err'), typeof act, exp);
assertTypeofNotEquals: function (/** @type {any} */ act, /** @type {string} */ exp, /** @type {string} */ msg) {
var _status = typeof act !== exp;
var _msg = sprintf('%s%s %s - act=%s, exp!=%s', (msg ? msg + ' -- ' : ''), 'assertTypeofNotEquals', (_status ? 'ok' : 'err'), typeof act, exp);
run: function() {
var test, i;
this.$out('Suite: ' + this.name);
for (i = 0; i < this.tests.length; i++) {
test = this.tests[i];
if (this.setup) this.setup();
this.$out('Running: ' + test.name);
try {
test.tester.apply(this);
this.$out('Test passed');
} catch (e) {
this.$out('Test failed: ' + e.message);
if (this.teardown) this.teardown();
this.$out();
// SAMPLE TESTS
var mut = new MUT({
autoFlush: true
mut.assertEquals(undefined, undefined, 'assertEquals undefined');
mut.assertEquals(null, null, 'assertEquals null');
mut.assertEquals(true, true, 'assertEquals boolean');
mut.assertEquals([].length, [].length, 'assertEquals null array lengths');
mut.assertEquals(JSON.stringify({}), JSON.stringify({}), 'assertEquals null object stringfied');
mut.assertEquals(new Date(2024, 0, 1).getTime(), new Date(2024, 0, 1).getTime(), 'assertEquals Date');
mut.assertEquals(new RegExp(/ab+c/).toString(), new RegExp(/ab+c/).toString(), 'assertEquals RegExp');
mut.assertNotEquals(null, undefined, 'assertNotEquals null');
mut.assertNotEquals(NaN, NaN, 'assertNotEquals NaN'); // NaNs in JS are never equal
mut.assertNotEquals(NaN, Infinity, 'assertNotEquals NaN');
mut.assertNotEquals(0, 1, 'assertNotEquals number');
mut.assertNotEquals(true, false, 'assertNotEquals boolean');
mut.assertNotEquals('Hello', 'World', 'assertNotEquals string');
mut.assertNotEquals([], [], 'assertNotEquals null array');
mut.assertNotEquals({}, {}, 'assertNotEquals null object');
mut.assertNotEquals([], [1], 'assertNotEquals null array');
mut.assertNotEquals({}, { a: 1 }, 'assertNotEquals null object');
mut.assertNotEquals(new Date(2024, 1, 2).getTime(), new Date(2024, 3, 4).getTime(), 'assertNotEquals Date');
mut.assertNotEquals(new RegExp(/ab+c/).toString(), new RegExp(/ab+c/i).toString(), 'assertNotEquals RegExp');
mut.assertTypeofEquals(undefined, 'undefined', 'assertTypeofEquals undefined');
mut.assertTypeofEquals(null, 'object', 'assertTypeofEquals null');
mut.assertTypeofEquals(NaN, 'number', 'assertTypeofEquals NaN');
mut.assertTypeofEquals(Infinity, 'number', 'assertTypeofEquals NaN');
mut.assertTypeofEquals(0, 'number', 'assertTypeofEquals number');
mut.assertTypeofEquals('Hello', 'string', 'assertTypeofEquals string');
mut.assertTypeofEquals([], 'object', 'assertTypeofEquals null array');
mut.assertTypeofEquals({}, 'object', 'assertTypeofEquals null object');
mut.assertTypeofEquals(function() {}, 'function', 'assertTypeofEquals function');
// mut.flush();
mut.addTest('Manual flush', function() {
mut.autoFlush = false;
mut.assertEquals(1, 1, 'number comparison');
mut.assertNotEquals('Hello', 'hello', 'case-sensitive comparison');
mut.assertTypeofEquals([], 'object', 'typeof array');
// mut.flush();
mut.run();
// if you want to collect the messages first so you can filter them out with own logic
// set both autoFlush & skipSuccess to FALSE, and pass a null function as callback
// and do NOT call flush in any of the addTest() methods
// e.g.
autoFlush: false,
skipSuccess: false,
mut2.run();
// sprintf - copied from my other scripts
// sprintf - BEGIN
// https://hexmen.com/blog/2007/03/14/printf-sprintf/
// from https://hexmen.com/js/sprintf.js
* JavaScript printf/sprintf functions.
* This code is unrestricted: you are free to use it however you like.
* The functions should work as expected, performing left or right alignment,
* truncating strings, outputting numbers with a required precision etc.
* For complex cases these functions follow the Perl implementations of
* (s)printf, allowing arguments to be passed out-of-order, and to set
* precision and output-length from other argument
* See http://perldoc.perl.org/functions/sprintf.html for more information.
* Implemented flags:
* - zero or space-padding (default: space)
* sprintf("%4d", 3) -> " 3"
* sprintf("%04d", 3) -> "0003"
* - left and right-alignment (default: right)
* sprintf("%3s", "a") -> " a"
* sprintf("%-3s", "b") -> "b "
* - out of order arguments (good for templates & message formats)
* sprintf("Estimate: %2$d units total: %1$.2f total", total, quantity)
* - binary, octal and hex prefixes (default: none)
* sprintf("%b", 13) -> "1101"
* sprintf("%#b", 13) -> "0b1101"
* sprintf("%#06x", 13) -> "0x000d"
* - positive number prefix (default: none)
* sprintf("%d", 3) -> "3"
* sprintf("%+d", 3) -> "+3"
* sprintf("% d", 3) -> " 3"
* - min/max width (with truncation); e.g. "%9.3s" and "%-9.3s"
* sprintf("%5s", "catfish") -> "catfish"
* sprintf("%.5s", "catfish") -> "catfi"
* sprintf("%5.3s", "catfish") -> " cat"
* sprintf("%-5.3s", "catfish") -> "cat "
* - precision (see note below); e.g. "%.2f"
* sprintf("%.3f", 2.1) -> "2.100"
* sprintf("%.3e", 2.1) -> "2.100e+0"
* sprintf("%.3g", 2.1) -> "2.10"
* sprintf("%.3p", 2.1) -> "2.1"
* sprintf("%.3p", '2.100') -> "2.10"
* Deviations from perl spec:
* - %n suppresses an argument
* - %p and %P act like %g, but without over-claiming accuracy:
* Compare:
* sprintf("%.3g", "2.1") -> "2.10"
* sprintf("%.3p", "2.1") -> "2.1"
* @version 2011.09.23
* @author Ash Searle
function sprintf() {
function pad(str, len, chr, leftJustify) {
var padding = (str.length >= len) ? '' : Array(1 + len - str.length >>> 0).join(chr);
return leftJustify ? str + padding : padding + str;
function justify(value, prefix, leftJustify, minWidth, zeroPad) {
var diff = minWidth - value.length;
if (diff > 0) {
if (leftJustify || !zeroPad) {
value = pad(value, minWidth, ' ', leftJustify);
} else {
value = value.slice(0, prefix.length) + pad('', diff, '0', true) + value.slice(prefix.length);
return value;
var a = arguments, i = 0, format = a[i++];
return format.replace(sprintf.regex, function (substring, valueIndex, flags, minWidth, _, precision, type) {
if (substring == '%%') return '%';
// parse flags
var leftJustify = false, positivePrefix = '', zeroPad = false, prefixBaseX = false;
for (var j = 0; flags && j < flags.length; j++) {
switch (flags.charAt(j)) {
case ' ': positivePrefix = ' '; break;
case '+': positivePrefix = '+'; break;
case '-': leftJustify = true; break;
case '0': zeroPad = true; break;
case '#': prefixBaseX = true; break;
// parameters may be null, undefined, empty-string or real valued
// we want to ignore null, undefined and empty-string values
if (!minWidth) {
minWidth = 0;
} else if (minWidth == '*') {
minWidth = +a[i++];
} else if (minWidth.charAt(0) == '*') {
minWidth = +a[minWidth.slice(1, -1)];
} else {
minWidth = +minWidth;
// Note: undocumented perl feature:
if (minWidth < 0) {
minWidth = -minWidth;
leftJustify = true;
if (!isFinite(minWidth)) {
throw new Error('sprintf (minimum-)width must be finite');
if (precision && precision.charAt(0) == '*') {
precision = +a[(precision == '*') ? i++ : precision.slice(1, -1)];
if (precision < 0) {
precision = null;
if (precision == null) {
precision = 'fFeE'.indexOf(type) > -1 ? 6 : (type == 'd') ? 0 : void (0);
} else {
precision = +precision;
// grab value using valueIndex if required?
var value = valueIndex ? a[valueIndex.slice(0, -1)] : a[i++];
var prefix, base;
switch (type) {
case 'c': value = String.fromCharCode(+value);
// eslint-disable-next-line no-fallthrough
case 's': {
// If you'd rather treat nulls as empty-strings, uncomment next line:
// if (value == null) return '';
value = String(value);
if (precision != null) {
value = value.slice(0, precision);
prefix = '';
break;
case 'b': base = 2; break;
case 'o': base = 8; break;
case 'u': base = 10; break;
case 'x': case 'X': base = 16; break;
case 'i':
case 'd': {
var number = parseInt(value, 10);
if (isNaN(number)) {
return '';
prefix = number < 0 ? '-' : positivePrefix;
value = prefix + pad(String(Math.abs(number)), precision, '0', false);
break;
case 'e': case 'E':
case 'f': case 'F':
case 'g': case 'G':
case 'p': case 'P':
// eslint-disable-next-line no-redeclare
var number = +value;
return '';
var method;
if ('p' != type.toLowerCase()) {
method = ['toExponential', 'toFixed', 'toPrecision']['efg'.indexOf(type.toLowerCase())];
} else {
// Count significant-figures, taking special-care of zeroes ('0' vs '0.00' etc.)
var sf = String(value).replace(/[eE].*|[^\d]/g, '');
var sf2 = (number ? sf.replace(/^0+/, '') : sf).length;
precision = precision ? Math.min(precision, sf2) : precision;
method = (!precision || precision <= sf2) ? 'toPrecision' : 'toExponential';
var number_str = Math.abs(number)[method](precision);
// number_str = thousandSeparation ? thousand_separate(number_str): number_str;
value = prefix + number_str;
break;
case 'n': return '';
default: return substring;
if (base) {
// cast to non-negative integer:
var number = value >>> 0;
prefix = prefixBaseX && base != 10 && number && ['0b', '0', '0x'][base >> 3] || '';
value = prefix + pad(number.toString(base), precision || 0, '0', false);
var justified = justify(value, prefix, leftJustify, minWidth, zeroPad);
return ('EFGPX'.indexOf(type) > -1) ? justified.toUpperCase() : justified;
sprintf.regex = /%%|%(\d+\$)?([-+#0 ]*)(\*\d+\$|\*|\d+)?(\.(\*\d+\$|\*|\d+))?([scboxXuidfegpEGP])/g;
// sprintf - END
