Navigate to shell folder using a button?
I'm trying to make a button that will take me to the Libraries shell folder that is new to Windows 7.
I can reach the folder through the tree, and I have made a folder alias for it, but I cannot seem to find a way to make a button that takes me there.
I tried dragging the folder to a toolbar, but the resulting button opens the shell folder using Explorer. I suppose turning on Replace Explorer would change this, but it's really not a viable option in Windows 7 at this point...
I assume I need to use its CLSID, but I cannot find the proper syntax.
Any help would be appreciated!
If you have a folder alias for it, try using the Go command to go there (eg Go /libraries)
Works fine. Thanks!
You can make buttons which go to shell folders by dropping the folders on a toolbar while Opus is in Customize mode.
Opus will fill in the details for you. (Usually an long IDL string since that's how shell folder paths work internally.)
Thanks Leo, but the drag/drop method wasn't working for me since I have Replace Explorer turned off - it doesn't work very well in Windows 7.
Clicking the button created that way just opened the shell folder in Explorer :slight_smile:
