function OnClick(clickData)
var eSel = new Enumerator(clickData.func.sourcetab.selected);
var getfoldername = eSel.item().realpath.filepart;
var re = /\s\([0-9]+?\)\.(.*)/;
var regfolder = getfoldername.replace(re, "");
cmd.SetSourceTab(cmd.desttab);
cmd.RunCommand('Set Focus=Toggle');
cmd.RunCommand('CreateFolder NAME="' + regfolder + '" READAUTO');
//After This Line, The Folder Created in the same label But
//I want to Create the Folder inside the folder which created from the Up side Code.
//for Open the folder I have used READAUTO but the folder doesnot create inside the folder
cmd.ClearFiles();
cmd.deselect = false;
var folderName = regfolder;
var matches = folderName.match(/^[^.]+/);
DOpus.Output(matches.length);
if (matches.length != 1) { return; }
var newName = matches[0] + ' Covers';
cmd.RunCommand('CreateFolder NAME="' + newName + '" READAUTO');
This Code has been created 2 Folder.
Folder1 has been Created from the Selected file name.
then the Folder2 has been Created from the Selected file names part.
They Works fine, But I want to create Folder2 inside Folder1
but the folders Created in same label.
