Hi,
I created a script to smartly select ALL or select NONE depending on currently selected items.
Edit: added the correction needed to work properly
Dim cmd, selCount
Set cmd = clickData.func.command
selCount = clickData.func.sourcetab.selected.count
If selCount <= 1 Then
' If no item or only 1 is selected then select ALL
cmd.deselect = false
cmd.RunCommand "Select ALL"
Else
' If more than one item is selected, unselect ALL
cmd.RunCommand "Select NONE"
End If
End Function
But when the select ALL
command runs, it selects ALL but unexpectedly deselect the currently selected item. Why ?
