I have mp3 files in folders which are named in this format:
nn.xxxx.mp3
...where nn is the track number (may be 1, 2 or 3 digits long) and xxxx is the track name.
I want to write a VBScript (triggered by a button) to process all mp3 files in the current folder and set the Track Number ID3 tag to the track number from the start of the filename (i.e. the bit before the ".").
This is what I have so far:
Option Explicit
Dim cmd, selItem, tracknum
If clickData.func.sourcetab.selected.count > 0 Then
For Each selItem in clickData.func.sourcetab.selected
tracknum = selItem.name_stem.Substring(0, selItem.name_stem.IndexOf("."))
'COMMAND HERE TO SET MP3 TAG TO tracknum!!'
Next
End If
I want to replace the 'COMMAND HERE TO SET MP3 TAG TO tracknum!!' line with the relevant command to do this. Can anyone advise what this command should be, or have I gone about this the wrong way?
Thanks for the pointer. How do I get the SetAttr META command to act on the selected item only in the loop (rather than applying the same change to all of the files in the selection)?
For each file, call ClearFiles on the command object you're using to clear any existing files inside it, then use AddFile to add just the file you want to affect to it.
Thanks. So the code below now produces this error:
Error at line 8, position 5
Object required: '[string: "06.The Ballad of Joh"]' (0x800a01a8)
(the first file is named "06.The Ballad of John Henry")
Option Explicit
Dim cmd, selItem, tracknum, strCommand
Dim myfilename, dlg
Set cmd = clickData.func.command
Set myfilename = selItem.name_stem
Set tracknum = myfilename.Substring(0, myfilename.IndexOf("."))
cmd.ClearFiles
cmd.AddFile(selItem)
strCommand = "SetAttr META track:" & tracknum
Shell.Run strCommand
Next
End If
End Function
Any idea why I get the "Object required" error here? (line 8 is "Set myfilename = selItem.name_stem")
The error is coming from the next line, which looks like it was from JScript. VBScript has functions like SubStr(...), not object methods like x.Substring(...)
Thanks. OK I finally managed to find some syntax which got past the parser (DOpus doesn't seem to like nested function calls)....
So the code below runs, but does not produce the expected result. I have 10 files selected in a folder when I run the script. They are numbered from 01 to 10 in the prefix of the filename. The script assigns a track number of "02" to the first 5 tracks, and a track number of "06" to the last 5 tracks.
As there's no debug function I can't work out where the logic is breaking down.
Any idea what's wrong?
Option Explicit
Dim myfilename, dlg, dotPos, Shell
Dim DOpusRTPath
DOpusRTPath = "C:\Program Files\GPSoftware\Directory Opus\dopusrt.exe"
Set Shell = CreateObject("WScript.Shell")
dotPos = Instr(myfilename,".")
dotPos = dotPos - 1
If dotPos > 0 Then
tracknum = Left(myfilename,dotPos)
Else
tracknum = "00"
End If
cmd.ClearFiles
strCommand = """" & DOpusRTPath & """ /cmd SetAttr META ""track:" & tracknum
Next
End If
End Function
Opus isn't involved in the parsing. VBScript is part of Windows.
You can use the DOpus.Output function to print things to the script log when you need to debug which commands etc. your script is running.
There's no need to use dopusrt for this, by the way. In fact, that is what's causing your problem. If you run the command via DOpusRT.exe, it's going to run that command independently of your script and the command will run on all files, not just the ones in your script's command object. Remove all the DOpusRT stuff and run the SetAttr command directly from the script.
OK I now have: SetAttr META "tracknumber:" & tracknum
...but it gives this error:
Expected end of statement (0x800a0401)
Parse error - script aborted
Here's the full script:
Option Explicit
dotPos = dotPos - 1
If dotPos > 0 Then
Else
tracknum = "00"
End If
cmd.ClearFiles
Next
End If
End Function
SetAttr is an Opus command, not a scripting function or object. Opus command should be run via the Opus command object, cmd in your script. The same object you add the files to is the one that should be used to run the command.
Have you looked at any other scripts to see how they run commands? I would start there. The default script you get in the button editor has an example where it runs Set VIEW=Details.
OK I've added logging and am trying to use the command object, based on examples elsewhere.
I now get this error:
Error at line 23, position 5
A method was called unexpectedly (0x8000ffff)
Line 23 is DOpus.Output = "strCommand =" & strCommand
I also see nothing in the Script Output console apart from this error message (i.e. no "Hello World" message).
Option Explicit
cmd.RunCommand("Set UTILITY=otherlog")
DOpus.Output("Hello, World in the Output Log")
DOpus.ClearOutput()
dotPos = dotPos - 1
If dotPos > 0 Then
Else
tracknum = "00"
End If
cmd.ClearFiles
strCommand = "SetAttr META tracknumber:" & tracknum
cmd.RunCommand(strCommand)
Next
End If
End Function
If I remove the offending Dopus.Output line the script will run. I see nothing in the Script Output window, but an error like this pops up in a dialog box for every file/iteration (and the tracknumber tags are not modified): "An error occurred setting metadata '01.I Know Where I Belong.mp3'; Metadata parsing error.
