Hello,
I am currently evaluating Directory Opus 13 and I really like it. I am trying to configure it to work similarly to the Windows 10 Explorer, especially with photographs.
I have one problem with Nikon Z8 NEF files.
When I select a NEF file in the file display, the Metadata panel on the right does not show the photographic EXIF information such as:
ISO
shutter speed
aperture
focal length
lens
camera model
date/time
However, when I open exactly the same NEF file in the Directory Opus Image Viewer (F10), all of this photographic information is displayed correctly.
So Directory Opus clearly can read the EXIF data from the Z8 NEF file.
My question is:
Is there any way to make the right-hand Metadata panel display the same photographic EXIF information that is shown in the F10 Image Viewer?
I would ideally like to have a layout similar to this:
Left/main area: large thumbnails of the photographs
Right panel: information about the currently selected photograph, including ISO, shutter speed, aperture, focal length, lens, camera model, etc.
I am aware that these values can be added as columns, but that is not what I am looking for. I specifically want the information in the right-hand panel for the currently selected image, similar to the Windows 10 Explorer Details pane.
If this is currently not possible, is there perhaps a script, add-on, or another way to achieve it?
Thank you.
