@nodeselect not working?
Image ROTATE=270 HERE REPLACE
@nodeselect
The above code does not seem to prevent the item selected from being unselected. After pressing once to rotate, the next item in the list seems to get the focus but is not highlighted/selected.
This does not allow me to rotate the image multiple times without re-highlighting/selecting.
Did you try the @nodeselect on top of the command, the other way around?
actually I believe did, although this is way the toolbar came with dopus too.
The selection gets lost because the selected files get deleted & replaced by the new versions.
Not sure if there is a workaround. If nobody else can come up with one it might be worth sending a feature request to GPSoft
