Hi. If I scroll down a very long list of folders, longer than will fit on one screen, open one and then close it again, the prog returns to show folders from the top of the list, and I have to re-scroll down if I want to see the folder I've just opened and closed. Is it possible to set things to return to the same position as it was before I opened the folder in question? Ta.
Use Back instead of Up.
There's a FAQ entry on this topic with all the info you should need:
Thanks, jon and nudel.
