EDIT: I restored v12 and noticed "Backup and Restore" doesn't work there also. I am assuming that "Backup and Restore" never worked in the portable version. Is there a way to import/export settings from the portable version in another way?
The "Back and Restore" menu item under "Settings" doesn't work.
When selecting it, nothing happens.
I am running dopus portable 13.5, windows 11 22H2
What I did is:
- Install dopus, then install correct certificate, then created exported an usb version.
- Fully exited the actual installed version, started the usb version to test if it started also wanted to test "Backup and Restore", it didn't work. Assuming this was maybe because the actual version was still installed.
- After the first boot test, I fully exited the usb version. Un-installed the actual install version.
- Started the usb version and tried "Backup and Restore" again, still nothing happens.
Also tried:
- starting in Admin mode, but selecting "Backup and Restore" still doesn't work
- Went to the preferences dialog just to close the welcome part in the settings, assuming that it might lock access to "Backup and Restore" until the welcome part was closed, but still nothing happens when selecting "Backup and Restore"
