OS : win 2004
DO : 12.21
Is there any progress with folder statuses?
I also use q-dir file manager and they also had problem with one drive status icons but they fixed that part few versions ago.
In file explorer is also working fine.
Make sure you are on the latest beta (not 12.21, which is older) and also disable all the OneDrive Mitigations via the registry setting to test if things are working now:
https://www.gpsoft.com.au/help/opus12/index.html#!Documents/windows101903mitigation.htm
Let us know if that works, since we were waiting on feedback from someone in another thread but haven't heard back yet.
Have you set the registry value?
Oops, sorry about that... Once I set the registry value, it's working!!!
