Open chrome images default picture viewer
Hello
can you please tell me, is there a way to make images downloaded on chrome when clicked to open from chrome's foot bar to open with Dopus's picture viewer ?
Thank you
Yes
Thank you
Checking it out now
I've been trying to change default viewer in win 10 but I just can't select d8 viewer no matter what I do, i can change into other programs but not d8viewer.exe, can you please help me ?
Recent updates to Windows 10 introduced a bug which completely breaks aspects of the Open With functionality.
Hopefully Microsoft will fix the OS, but they still haven't at least a month later.
As a workaround you can fix things by following the additional steps here:
I've added the same information to the FAQ.
Thank you
does that mean if I want to do change jpg default file handler it should be
ftype jpegfile="C:\Program Files\GPSoftware\Directory Opus\d8viewer.exe" %1
is that it ?
Yes !!
Finally got this solved
Just cannot believe the hassle it take to get this done in win 10
Thank you very much !
Now there is only just one more thing i have UAC on first level of protection meaning that when I open the image UAC prompt asks for authorization to open d8viewer, I already have d8viewer with admin privilege, is there any other way to not trigger the the UAC prompt ?
Make sure none of the Compatibility settings have been turned on for any of the Opus executables:
