If it's in a folder then you need to specify the folder name as well.
I don't know where the folder starts. I'm sure it's not A:
Bob
If the folder name is "Directory Paths" then the layout path would be "Directory Paths\opusUTY". Because "Directory Paths" has a space in it you'll need to put quotes around it, but from looking at the docs of the Dragon thing it looks like it doesn't support command lines containing spaces. So you might want to rethink the name of that folder.
Absolutely. I've been fighting this too long. I definitely will change the name of the file and thanks for the help.
Bob
I changed the code to:
A:\AX!UTY\opus\dopusrt.exe /cmd Prefs "BasePaths\LAYOUT=opusUTY"
Win R did execute. But it only brought up my Preferences-Directory Opus\Layouts.
It displayed my two folders in the layout.
BasePaths
TechSmith
And stopped.
A:\AX!UTY\opus\dopusrt.exe /cmd Prefs LAYOUT=BasePaths\opusUTY
It works. A:\AX!UTY\opus\dopusrt.exe /cmd Prefs LAYOUT=opusUTY
Notice I removed the folder from the layout. Since Wayne was I could not open the layout. There was something about the layout folder that didn't work out. But now I got it running without the folder.
Thanks for all the help Jon and the many more that also help.
Bob
