That depends entirely on the program you open the file in, unless you want to start modifying file attributes or file permissions in response to double-click (which probably isn't a good idea).
You could also do it by copying the file to the temp folder and opening the copy instead of the real file, which could be automated. (That would only work if the file was standalone and didn't depend on other files in the same folder, or if all the supporting files were copied as well.)
If a program has a way to tell it to open files in read-only mode via the command line, then you can do that from Opus. But it's really up to the program what it does; Opus just passes the file path and any other arguments to the program, and the program is what opens the file.
