Hi, are there any plans to add more options for the background of the viewer pane? Having a solid fill is ok but simple colors like white, black, grey, etc can cause confusion between files that may or may not be transparent. The alternative is to choose an uncommon color but it gets a little tired looking at images on a bright green or purple background all day (and doesn't completely eliminate the possibility of the first issue).
It would be great to have an option for a checkerboard or something similar to indicate transparency. Just wondering if this is anywhere on the dopus roadmap, thanks!
