Options to remove folder icon and lock icon from tabs
Could there possibly be options to remove the folder icon and the lock icon from the tabs? I have been locking some tabs in my tabgroups, and now the tabnames are partly hidden, because with the two icons left and right of each tab name, there is not enough room across the display. I'd like to see just the tabnames, each alone in its little rectangle.
  • The folder icon is already a problem, because the icon in the tab doesn't always match the icon in the display above it.
  • The lock icons are useful, but not as useful as seeing all the tabnames at once without any irritating scrolling or popups. (By the way, if there were coloured tabs, we could assign different colours to the four lock possibilities.)
Such options would be very much in the spirit of DOpus' amazing flexibility (I've already removed the close icon). Apologies if, once again, I am missing possibilities that are already there — which is one reason why it is always worth asking.
That's something we'd like to fix, if you can give more detail on when it happens.
  • If I use DOpus to change the colour of the icon using Preferences - - > File and Folder Labels - - > Create a new wildcard label, the change is not carried through to the folder icon in the tab.
  • If I use Windows to change the icon using RightClick on the Folder - - > Properties - - > Customize - - > Change Icon, the change is carried through to the folder icon in the tab, whether or not a tabname has been set.
