Hi,
I'm having problems on connecting to FTP to one specific server.
I've tried every single setting (If I'm not wrong) I've found on Opus to try to set the FTP connection settings to that specific FTP server
I've surrended and installed another FTP program, FileZilla and it worked.
I don't want to use FileZilla because I prefer my loved DOpus
The main difference is the FTP over implicit TLS/SSL that I cannot found in DOpus options. Only explicit TLS or implicit SSL not TLS.
Thank you for your support and making the best "multi-purpose knife" utility not only.
I'm pasting here configs and Logs of both programs if it helps you what's going on
Is it definitely the right IP in the yy,yy,yy,yy part? It should normally be the same IP that you connected to the server with at the top of the log.
Some servers are misconfigured and when put into passive mode will ask the client to connect to the wrong IP address (usually an internal LAN IP that the client cannot see), which might be what's happening here.
Yes I am, Jon.
FileZilla hasn't got a different configuration than DOpus. In fact, both of them share the same kind of network configuration/setup.
Leo, I was wrong when I wrote my first post. In fact, I was thinking that the IP was an internal/LAN IP but I wrote it wrong.
But what does FileZilla do to "bypass" that issue if it's related to the internal IP?? Can DOpus just try again with the first IP (xx.xx.xx.xx)? I ask this because FileZilla's log seems to show that behaviour, but maybe I'm wrong.
