I have default Opus 13.5 installed. I would now like to install Opus 12 So I can compare both. I did a backup, Opus, before installing Opus 13. I than removed Opus 12. So I will some how have to use the Opus 12 backup, if that's possible.
Bob
To go from Opus 13 to Opus 12:
- Backup your Opus 13 config (Settings > Backup & Restore).
- Uninstall Opus, and reboot when prompted
- Install Opus 12, and restore your Opus 12 config backup.
To go from Opus 12 to Opus 13:
- Backup your Opus 12 config. (Settings > Backup & Restore)
- Install Opus 13 over the top of Opus 12, and reboot if prompted.
I want to have both available on the same computer.
Bob
You can't have two listers from different versions simultaneously. You need to put one version into a Sandbox or VM, or use a USB export to change back and forth.
