Recently my Opus stopped to show previews of video files. But sometimes some preview still shows. The reason I did not find one. What do I do?
The one that works is probably just cached.
I cleared the cache and register splitters for Opus (mp4, mkv, flv), but did not fix: some mp4, mkv, avi files have a preview, and some do not. There are other ideas?
All the other stuff in the FAQ. Codecs (not just splitters), registry settings if something has damaged the filetypes (VLC is a common culprit for that).
Presumably Windows Explorer cannot get thumbnails for the files either?
You can try what I do. I get great results:
https://resource.dopus.com/t/video-thumbnails-in-directory-opus/12232/1[/quote]
Thank you - now my opus works fine ![]()
Open * Codec Tweak Tool* Select DirectShow 64bit then Tick all and Apply all and close
Done!
