Hi,
I'm using dopus FTP client to connect to multiman ftp server.
I don't know why but the opus client is not able to parse the directory listing returned by the server. Opus gives no error but the distrory listing is empty.
I have been able to log the format using a command line ftp client:
ftp> ls
200 PORT command successful
150 Accepted data connection
dr-xr-xr-x 1 root root 258 Jan 01 00:59 .
drwx--x--x 1 root root 16384 Jan 01 01:00 dev_flash
drwx--x--x 1 root root 16384 Jan 01 01:00 dev_flash2
drwx--x--x 1 root root 16384 Jan 01 01:00 dev_flash3
drwx[nowrap]r[/nowrap]-xr-x 1 root root 512 May 20 17:56 dev_hdd0
dr-xr-xr-x 1 root root 2048 Jan 29 13:08 dev_bdvd
drwx--x--x 1 root root 32768 Jan 01 01:00 dev_hdd1
226 Transfer complete
Can you check why opus ftp has a problem with this format ?
Thank you.
Florent
