Opus icons and files look big when i connect my laptop to my monitor. This only happens for directory opus application, all other applications look normal in size, same as my laptop screen.
Use File > Exit Directory Opus, then re-open it. Are things normal size then?
nothing happened. issue still there.
any solutions?
I just noticed your profile says you're using Opus 11. DPI support was added in Opus 12.
so I've to upgrade to opus 12. Correct?
If you want high DPI support, yes.
Thanks a lot. Much Appreciated.
