OPUS not working after 13.12
Ever since updating to 13.12 last week, DO will open but I cannot move, copy, delete, or rename files at all. Even right clicking and trying those actions doesn't work.
I CAN open files through it.
I've uninstalled completely, restarted, and reinstalled. I've tried 13.11 and 13.1, still the same thing.
What happens when you try? Is there an error message?
Which locations have you tried copying between?
Have you tried other file types? (E.g. Antivirus might block some types from being accessed.)
Are other programs able to copy things?
No error message, it just doesn't do anything.
I've tried copying between local folders and to a network folder
I've tried on multiple file types.
Windows explorer works fine.
How are you doing the copy?
Try using the Copy Files button on the toolbars in case it’s only drag & drop or the clipboard which aren’t working, as that’ll tell us where to look for the cause.
Tried that, still nothing. Just doesn't do anything.
Do a config backup (Settings > Backup & Restore), then try the config Reset option in the same dialog.
Does copying work now or still not?
If it still doesn’t work, I’d say something is sandboxing Opus and blocking it from touching the files in question.
Thanks Leo, that narrows it down. It works on a reset configuration, that narrows it down to something local for me.
Thanks for your help!
