Opus using high CPU via clipboard / Remote Desktop
Opus goes into a high CPU state after using the clipboard “anywhere” in the system, but “only” if remote desktop is running (top) or (background) level.
  • Opus stays in this high cpu state (>50%) until remote desktop is closed. After remote desktop is closed, Opus CPU (0%).
  • Doesn’t matter where clipboard is used (not specific to Opus or remote desktop), as long as remote desktop is running.
I’ve tried disabling remote desktop’s clipboard service via services and in remote desktop’s launch window properties - nothing resolves?
Any help appreciated!
This thread might be relevant: DO 10 causes high MSTSC cpu usage
Jon-
Relevant indeed, and nice to know it's not virus related. The effected workstation will be replaced soon with win7, so problem solved!
Thanks
