Opus V9 and user command button small problem
I made a very simple button that does 3 copies like this...
@NoDeselect
Copy to=z:
Copy to=d:\Archive
Copy to=e:\DVD-ram\
In version 8 it worked fine, however in version 9 the copy progress bar never shows up and I have to check to see if all files did indeed copy. The copy does happen but there is never any kind of display even for a very long copy. If there is an error then I do get a display window. Thanks.
Edit : This is with Windows XP Pro.
Try disabling Delayed Progress indicator, or reducing the delay.
It is, still no copy display even with a very large single file copy. Thanks.
Please, edit the button you are using to start the copy operation and paste its command here so we can see it.
Simply ...
@NoDeselect
Copy to=z:
Copy to=d:\Archive
Copy to=e:\DVD-ram\
Thanks.
I cannot recreate this, On XP or Vista.
Do you have all the options I have above set the same way?
More info...
Yes, it is same as yours. Thanks.
Make sure your preferences are set exactly like mine above (not just the the highlighted ones).
Okay, I'm clueless as to what else it could be. Best to submit an official support request (click in my signature) and include a concise description, plus a link to this thread (right click the anchor link in your first post and select Copy Shortcut).
