If i have a movie with AC3 audio, should Opus display that in the Audio Codec column? All my AC3 movies have a blank for Audio Codec. I know these are AC3 files from other programs identifying them as such.
thanks
thanks
Opus gets the codec information from the Windows Media sub-system. If Explorer recognises the codec then Opus should too - what do you see if you do 'Properties' on the file (then click the Summary tab, Advanced)?
Hmmm, says "properties not available for selected source". Winmx and Gspot both identify it as AC3.
What now?
You may need to install an AC3 codec so that Windows Media Player & friends can recognise it. Can you hear the audio if you play the file in Windows Media Player?
Interesting... audio plays fine with WMP. I use Gspot to look at list of installed codecs, and the AC3 one says 'improperly registered" and some say "not registered".
I am guessing i need to reinstall. 2 questions:
Where can i find a quality codec pack with AC3?
How can i uninstall codecs and start from scratch?
I will answer one of my own questions.. see this link from author of Gspot to see how to uninstall codecs...
ffdshow seems to include an AC3 decoder these days. I don't know if it's the best one or not, though.
I installed ac3 filter, and it shows up with Gspot as registered and installed, but Opus does not show AC3.
Something else, i lookead at the properties for another video file that Opus showed all codec data for , and it gave me the same message ....
"properties not available". \
Now i really am confused.
I have tried 3 different AC3 filters. Opus would not recognize any of them. I finally settled on the KLite AC3 installation of it, and removed the others.
i like to keep track of the audio and video for my movies, so if anyone has any suggestions i would welcome them.
Do you have a small example movie you could send me to try with?
Jon, i could send you the entire file or try and split part of it out with Nero, i suppose. Never done it but i could try and then verify with Gspot that it is AC3.
Another issue, MPEG-2 video doesnt show up either, and i have MPEG-2 filter installed.
Something i liked about the Klite codec pack, it gives you the option of unistaling other codecs it includes so you dont duplicate codecs. Also, it checks for broken codecs and lets you clear those.
Let me know if you want a split file, sounds like that is the best. I will try it and have sample available.
Got that, I'll see what I can find.
Jon,
here is a list of what Gspot says i have... looks like hell in this window, hope you can read it. I noticed that i have several AC3 filters and one says file missing. AC3 plays just fine.
Oh, and an option for the KLite pack was "container" filters. What is a container file and do i need container filters?
By the way, fantastic support you all have in this forum!!!
DSH Infinite Pin Tee Filter {F8388A40-... 0x0020... qcap.dll
DSH {321D3CFB... 0x0020... NeAudioEnc.ax
DSH DV Scenes {13935B88-... 0x0020... NVDV.dll
DSH Nero Resize {30002E0C-... 0x0020... NeResize.ax
DSH SampleGrabber {C1F400A0-... 0x0020... qedit.dll
REND Null Renderer {C1F400A4-... 0x0020... qedit.dll
DSH IV41 Indeo® video 4.4 Dec... {31345649-... 0x0064... ir41_32.ax
DMO MP43 Mpeg43 Decoder DMO {CBA9E78B... 0x0080... qasf.dll --> mp43dm...
DMO MP4S Mpeg4s Decoder DMO {2A11BAE2... 0x0080... qasf.dll --> mp4sdmo...
DMO MPG4 Mpeg4 Decoder DMO {F371728A-... 0x0080... qasf.dll --> mpg4dm...
DSH NDIG Nero Digital AVC Muxer {426F6A6F-... 0x0020... NeNDMux.ax
DSH QDMC Nero QuickTime(tm) A... {D6D8A64E... 0x0040... NeQTDec.ax
DMO WMVA WMVideo Advanced ... {03BE3AC4... 0x0080... qasf.dll --> wmvadv...
DSH XVID DivX Decoder Filter {78766964-... 0xff800... divxdec.ax
DSH ZYGO Nero QuickTime(tm) Vi... {470157A6-... 0x0040... NeQTDec.ax
ACM ACELPnet Audio codec for MS A... msacm.sl_a... 0x0020... quartz.dll --> sl_anet...
DSH ACELPnet ACELP.net Sipro Lab ... {4009F700-... 0x0080... acelpdec.ax
DSH Audio CoreVorbis Audio Dec... {0835DC4B... 0x0080... CoreVorbis.ax
DSH Audio 3ivx D4 Audio Decoder {68D0B5CF... 0x0060... 3ivxDSAudioDecod...
DSH Audio ACM Wrapper {6A08CF80-... 0x0060... quartz.dll
DSH Audio WMT Volume {EFEE43D6... 0x0020... wmm2filt.dll
DSH Audio IAC2 {6A08CF80-... 0x0020... quartz.dll
DSH Audio IMA ADPCM {6A08CF80-... 0x0020... quartz.dll
DSH Audio PCM {6A08CF80-... 0x0020... quartz.dll
DSH Audio Microsoft ADPCM {6A08CF80-... 0x0020... quartz.dll
DSH Audio ACELP.net {6A08CF80-... 0x0020... quartz.dll
DSH Audio DSP Group TrueSpee... {6A08CF80-... 0x0020... quartz.dll
DSH Audio Windows Media Audio... {6A08CF80-... 0x0020... quartz.dll
DSH Audio GSM 6.10 {6A08CF80-... 0x0020... quartz.dll
DSH Audio Microsoft G.723.1 {6A08CF80-... 0x0020... quartz.dll
DSH Audio CCITT A-Law {6A08CF80-... 0x0020... quartz.dll
DSH Audio CCITT u-Law {6A08CF80-... 0x0020... quartz.dll
DSH Audio AC-3 ACM Codec {6A08CF80-... 0x0020... quartz.dll
DSH Audio MPEG Layer-3 {6A08CF80-... 0x0020... quartz.dll
DSH Audio WMT AudioAnalyzer {1CB1623E-... 0x0020... wmm2filt.dll
REND Audio Intel(r) Integrated Audio{E30629D1-... 0x0020... quartz.dll
REND Audio Default WaveOut Dev... {E30629D1-... 0x0020... quartz.dll
DSH AUXLine21Data Line 21 Decoder 2 {E4206432-... 0x0060... quartz.dll
DSH AUXLine21Data Line 21 Decoder {6E8D4A20... 0x0060... qdvd.dll
DSH Avi AVI Splitter {1B544C20-... 0x0060... quartz.dll
VFW CVID Cinepak Codec by Ra... vidc.cvid 0x0020... quartz.dll --> iccvid.dll
VFW DIVF DivX Codec 4.12 vidc.divf 0x0020... quartz.dll --> DivX41...
VFW DIVX DivX® 5.2.1 Codec vidc.divx 0x0020... quartz.dll --> divx.dll
DSH DOLBY_AC3 AC3Filter {A753A1EC... 0x4000... ac3filter.ax
DSH DOLBY_AC3 CyberLink Audio Deco... {DE11F7D8... 0x0060... claud.ax
DSH DOLBY_AC3 CyberLink Audio Deco... {9BC1B780-... 0x0060... claud.ax
DSH DOLBY_AC3 AC3 Parser Filter {280A3020-... 0x0060... mpg2splt.ax
DSH DOLBY_AC3 AC3Filter (Dr.DivX) {2BCCD45E... 0x0040... AKE007.ddc
DSH DOLBY_AC3 {CF80B1DD... 0x0020... ** File Missing:
DSH DVSD DV Video Decoder {B1B77C00-... 0x0080... qdv.dll
DSH DVSD DV Splitter {4EB31670-... 0x0060... qdv.dll
DSH DVSD Nero DV Splitter {F85D4921-... 0x0020... NeDVSplitter.ax
DSH File File stream renderer {D51BD5A5... 0x0040... quartz.dll
ACM FmtTag: 0x00... Microsoft ADPCM CO... msacm.msa... 0x0020... quartz.dll --> msadp...
ACM FmtTag: 0x00... Microsoft CCITT G.71... msacm.msg... 0x0020... quartz.dll --> msg71...
ACM FmtTag: 0x00... IMA ADPCM CODEC f... msacm.imaa... 0x0020... quartz.dll --> imaadp...
ACM FmtTag: 0x00... DSP Group TrueSpee... msacm.trspch 0x0020... quartz.dll --> tssoft3...
ACM FmtTag: 0x00... Microsoft GSM 6.10 A... msacm.msg... 0x0020... quartz.dll --> msgsm...
ACM FmtTag: 0x00... Microsoft G.723.1 CO... msacm.msg... 0x0020... quartz.dll --> msg72...
ACM FmtTag: 0x00... MPEG Layer-3 Audio ... msacm.l3acm 0x0020... quartz.dll --> L3code...
DSH FmtTag: 0x00... MPEG Layer-3 Decoder {38BE3000-... 0x0081... l3codecx.ax
ACM FmtTag: 0x01... DivX WMA Audi msacm.divx... 0x0020... quartz.dll --> divxa3...
ACM FmtTag: 0x01... Windows Media Audio msacm.msa... 0x0020... quartz.dll --> msaud...
DMO FmtTag: 0x01... WMAudio Decoder D... {2EEB4ADF... 0x0080... qasf.dll --> wmadmo...
ACM FmtTag: 0x04... Indeo® audio software msacm.iac2 0x0020... quartz.dll --> iac25_...
ACM FmtTag: 0x20... AC-3 ACM Codec msacm.ac3... 0x0020... quartz.dll --> ac3ac...
VFW I420 Intel 4:2:0 Video V2.50 vidc.i420 0x0020... quartz.dll --> msh26...
VFW IV32 Intel Indeo(R) Video R...vidc.iv32 0x0020... quartz.dll --> ir32_32...
VFW IV41 Intel Indeo® Video 4.5 vidc.iv41 0x0020... quartz.dll --> ir41_32...
VFW IV50 Indeo® video 5.10 vidc.iv50 0x0020... quartz.dll --> ir50_32...
VFW IYUV Intel IYUV codec vidc.iyuv 0x0020... quartz.dll --> iyuv_3...
DSH IYUV Color Converter {637E3E39-... 0x0020... declrds.ax
DSH LMRT ASF embedded stuff ... {B9D1F32E... 0x0060... wmpasf.dll
VFW M261 Microsoft H.261 Video... vidc.m261 0x0020... quartz.dll --> msh26...
VFW M263 Microsoft H.263 Video... vidc.m263 0x0020... quartz.dll --> msh26...
DSH Midi MIDI Parser {D51BD5A2... 0x0040... quartz.dll
REND Midi Default MidiOut Device {07B65360-... 0x0080... quartz.dll
REND Midi Microsoft GS Waveta... {07B65360-... 0x0020... quartz.dll
DSH MJPG AVI Draw {A888DF60-... 0x0060... quartz.dll
DSH MJPG MJPEG Decompressor {301056D0-... 0x0060... quartz.dll
DSH MPEG1Packet MPEG Video Decoder {FEB50740-... 0x4000... quartz.dll
DSH MPEG1Packet MPEG Audio Decoder {4A2286E0-... 0x0368... quartz.dll
DSH MPEG1Packet Nero Digital Audio De... {138130AF-... 0x0060... NeAudio.ax
DSH MPEG1Packet CyberLink Video/SP ... {DE111E5E... 0x0060... CLVSD.ax
DSH MPEG1Packet CyberLink Video/SP ... {9BC1B781-... 0x0060... clvsd.ax
DSH MPEG1System MainConcept MPEG ... {2BE4D120... 0x0060... mcspmpeg.ax
DSH MPEG1System MPEG-I Stream Splitter {336475D0-... 0x0060... quartz.dll
DSH MPEG2_VIDEO Nero DVD Decoder {DCD6EAD... 0x0060... NeVideo.ax
DSH MPEG2_VIDEO Nero Video Decoder {C0BA9CF8... 0x0060... NeVideo.ax
VFW MRLE Microsoft RLE vidc.mrle 0x0020... quartz.dll --> msrle32...
DSH MSS1 Microsoft Screen Vide... {3301A7C4-... 0x0080... msscds32.ax
DMO MSS1 WMV Screen decoder... {7BAFB3B1... 0x0080... qasf.dll --> wmsdmo...
VFW MSVC Microsoft Video 1 vidc.msvc 0x0020... quartz.dll --> msvidc...
DSH PCM Indeo® audio software {B4CA2970-... 0x0050... iac25_32.ax
DSH PCM CyberLink TimeStretc... {DE1167CB... 0x0020... clauts.ax
DSH PCM CyberLink Audio Effect {DE117A61... 0x0020... CLAudFx.ax
DSH PCM Vorbis Encoder {889EF574-... 0x0020... OggDS.dll
DSH PCM CyberLink Audio Effect {3D5455E5-... 0x0020... claudfx.ax
DSH PCM Nero Audio Processor {79D28B7F-... 0x0020... NeAudioConv.ax
DSH PCM G.711 Codec {AF7D8180-... 0x0020... g711codc.ax
DSH PCM Nero Digital AVC Audi... {426F6A6F-... 0x0020... NeNDAud.ax
REND PCM Default DirectSound ... {79376820-... 0x0080... quartz.dll
REND PCM DirectSound: Intel(r) In.{79376820-... 0x0020... quartz.dll
DSH QTMovie QuickTime Movie Par... {D51BD5A0... 0x0060... quartz.dll
DSH QTRpza QT Decompressor {FDFE9681-... 0x0060... quartz.dll
DSH RGB24 Uncompressed Domai... {CFFB1FC7-... 0x0020... wmm2filt.dll
DSH RGB24 ShotBoundaryDet {FE48704D-... 0x0020... wmmfilt.dll
DSH RGB24 Bitmap Generate {4F3E50BD... 0x0020... wmm2filt.dll
DSH RGB8 Color Space Converter {1643E180-... 0x0040... quartz.dll
DSH RGB8 VGA 16 Color Ditherer {1DA08500-... 0x0040... quartz.dll
REND ScriptCommand Internal Script Comma... {48025243-... 0x0080... quartz.dll
DSH Stream ASX file Parser {640999A0-... 0x0060... wmpasf.dll
DSH Stream NSC file Parser {640999A2-... 0x0060... wmpasf.dll
DSH Stream Nero Splitter {A336CD3B... 0x0060... NeSplitter.ax
DSH Stream Multi-file Parser {D51BD5A3... 0x0040... quartz.dll
DSH Stream SAMI (CC) Parser {33FACFE0-... 0x0040... quartz.dll
REND Stream ASX v.2 file Parser {640999A1-... 0x0060... wmpasf.dll
REND Stream .RAM file Parser {A98C8400-... 0x0060... wmpasf.dll
DSH TELETEXT WST Decoder {70BC06E0-... 0x0060... wstdecod.dll
DSH Text Lyric Parser {D51BD5A4... 0x0040... quartz.dll
¤ Video AVI Decompressor {CF49D4E0... 0x0060... quartz.dll
DSH Video Overlay Mixer2 {A0025E90-... 0x0040... qdvd.dll
DSH Video WMT Interlacer {C6CB1FE3... 0x0020... wmm2filt.dll
DSH Video WMT DV Extract {E476CBFF-... 0x0020... wmm2filt.dll
DSH Video WMT Switch Filter {EF105BC3-... 0x0020... wmm2filt.dll
DSH Video Stretch Video {F44BB2D0... 0x0020... wmm2filt.dll
DSH Video Indeo® video 4.4 Com... {A2551F60-... 0x0020... ir41_32.ax
DSH Video Indeo® video 5.10 Co... {1F73E9B1-... 0x0020... ir50_32.dll
DSH Video WMT Format Conversi... {2D20D4BB... 0x0020... wmm2filt.dll
DSH Video WMT Black Frame Ge... {2EA10031-... 0x0020... wmm2filt.dll
DSH Video muvee HXImage Filter {3E1434A3-... 0x0020... HXImageFilter.ax
DSH Video WMT VIH2 Fix {586FB486-... 0x0020... wmm2filt.dll
DSH Video Record Queue {5B4B05EB... 0x0020... wmm2filt.dll
DSH Video Disk Record Queue {5BB4BE4A... 0x0020... wmedque.dll
DSH Video Frame Eater {6C68955E-... 0x0020... wmm2filt.dll
DSH Video WMT Sample Informat... {7F1232EE-... 0x0020... wmm2filt.dll
DSH Video Nero PS Muxer {8E584C5D... 0x0020... NePSMuxer.ax
DSH Video WMT Log Filter {92883667-... 0x0020... wmm2filt.dll
DSH Video WMT DirectX Transfo... {AECF5D2E... 0x0020... wmm2filt.dll
DSH Video 9x8Resize {BC0D69A8... 0x0020... wmm2filt.dll
DSH Video WIA Stream Snapshot... {BC7ACB90... 0x0020... wiasf.ax
DSH Video Allocator Fix {C0D076C5... 0x0020... wmm2filt.dll
DSH Video Smart Tee {CC58E280-... 0x0020... qcap.dll
REND Video Video Renderer {6BC1CFFA... 0x0080... quartz.dll
REND Video Video Renderer {70E102B0-... 0x0040... quartz.dll
REND Video Full Screen Renderer {07167665-... 0x0020... quartz.dll
REND Video Video Mixing Rendere... {51B4ABF3-... 0x0020... quartz.dll
DSH Vorbis Vorbis Decoder {02391F44-... 0x0060... OggDS.dll
DSH VPVBI VBI Surface Allocator {814B9800-... 0x0060... vbisurf.ax
DSH VPVideo Video Port Manager {6F26A6CD... 0x0060... quartz.dll
DSH WAVE Wave Parser {D51BD5A1... 0x0040... quartz.dll
DSH WM9_ASF_U... Windows Media Multi... {63F8AA94-... 0x0060... wmpasf.dll
DSH WM9_ASF_U... ASF DIB Handler {B9D1F320-... 0x0060... wmpasf.dll
DSH WM9_ASF_U... ASF ACM Handler {B9D1F321-... 0x0060... wmpasf.dll
DSH WM9_ASF_U... ASF ICM Handler {B9D1F322-... 0x0060... wmpasf.dll
DSH WM9_ASF_U... ASF URL Handler {B9D1F323-... 0x0060... wmpasf.dll
DSH WM9_ASF_U... ASF JPEG Handler {B9D1F324-... 0x0060... wmpasf.dll
DSH WM9_ASF_U... ASF DJPEG Handler {B9D1F325-... 0x0060... wmpasf.dll
ACM WMAudioV2 DivX WMA Audi msacm.divx... 0x0020... quartz.dll --> divxa3...
ACM WMAudioV2 Windows Media Audio msacm.msa... 0x0020... quartz.dll --> msaud...
DSH WMAudioV2 Windows Media Audio... {22E24591-... 0x0080... msadds32.ax
DMO WMAudioV9 WMAPro over S/PDIF... {5210F8E4-... 0x0000... qasf.dll --> wmadmo...
DMO WMSP1 WMSpeech Decoder ... {874131CB-... 0x0000... qasf.dll --> wmspdm...
DSH WMV1 Windows Media Video... {4FACBBA1... 0x0080... wmvds32.ax
DMO WMV1 WMVideo Decoder D... {82D353DF... 0x0080... qasf.dll --> wmvdmo...
DSH WMV2 Windows Media Video... {521FB373-... 0x0080... wmv8ds32.ax
VFW XVID XviD MPEG-4 Codec vidc.xvid 0x0020... quartz.dll --> xvidvfw...
DSH YUY2 Nero Mpeg2 Encoder {7FEBD653... 0x0020... NeVCR.ax
DSH YV12 MainConcept MPEG ... {2BE4D150... 0x0020... mcesmpeg.ax
DSH YV12 Nero Frame Capture {EBED89A0... 0x0020... NeCapture.ax
DSH YV12 Nero Format Converter {4BE81DEE... 0x0020... NeroFormatConv.ax
DSH YV12 Nero Video Processor {BCDE0277... 0x0020... NeroVideoProc.ax
DSH YV12 Nero Digital AVC Vide... {426F6A6F-... 0x0020... NeNDVid.ax
Sorry, i didnt realize how long that posting would be. Jon, feel free to delete my previous posting when you get the data from it.
rh
