Opus8 is chrashing if Sony Ericsson PC Suite is loaded
Hi!
I'm not able to use Opus 8 8.2.2.5 together with Sony Ericsson PC Suite for Smartphones, version: 1.2.15. When trying to start Opus 8 it closes down right after it's finish loading. If I uninstall SE PC Suite Opus 8 is working fine...
Does any have a solution (not uninstalling SE PC Suite...)?
Which phone is this for? I can't find a download link to it on SE's website since you have to know the phone to find the software.
I've got a P900 sitting around here which used PC Suite 3.1.1 without problems in Opus but it sounds like PC Suite for Smartphones is a different beast due to the version number reset. Maybe I can install it anyway without the phone, but I can't even find it on their site so far. :slight_smile:
It is for SE P990i
When I had SE P910i Opus 8 worked without any problems...
I also have SE P800i but I have to install a different Suite for that. The latest on that I use together with P990i is not recognizing my P800i :frowning:
I've not had a chance to install the software to confirm the problem also happens for me as I've been really busy/ill lately. You should send a support request to GPSoftware so they can look into it.
OK. I'll do that.
(my other phone is SE K800i and not P800i :laughing: )
