Organize Quick Access
Hello new user here,
Im really liking Dopus. However, I am having trouble finding how to organize the quick access folders. By this, I mean the list of folders that I save to my quick access at the top of the file structure. In windows file explorer, all I had to was drag them in the order of preference. How can I rearrange them to my liking?
Thanks,
Joe
We haven't found a way to do that yet; Microsoft's view appears to be that reordering them should only be done in Explorer. If you change them in Explorer then Opus should reflect the new order automatically.
I understand. Actually, i figured that out immediately after writing this message to the forum. Thank you for your response.
@jwenga how did you about changing the order with explorer? i havent used windows explorer sense windows 7. haha.
dopus & everthing are install first stop and then i never look backwards.
You can drag Quick Access folders up and down in Explorer's folder tree to reorder them.
ill check it out. i usally dont use the quick access in thru the dialoge much. with listary ctrl+g bring you instantly to open or last active directory from dopus. been building a new system the past month. digging under the hood a bit more
im also kind of new to win10. i was a win7 die-hard-hold-out for long time, then went linux for a couple years, starting to love win10 after a year, now its reaching end of life.
