Out of RAM
Last couple of days i see a picture like that
Clipboard Image
Dopus is use 30+ GB of RAM. It laggy and won't switch tab or select files.
Same time the Windows Explorer is fine. Smooth and not laggy.
How to reproduce: Don't know. I just ising it like for years ago
How to solve: Kill process and open doppus again. But it accumulate RAM just in run. about 50mbps. Even if it closed.
dopus version: 13.4
UPD: I think I found the issue. Probably it was Tab Lock icons. It is the only things I changed after apdate to v13. I removed that icon-pack, and now is all fine.
I'd be surprised if an iconset caused such a large memory leak. (Not impossible, but not something I'd expect.)
Memory leaks are often (although not always) caused by shell extensions something else has installed. If it comes back, this guide can help track things down (although it is on the technical side of things):
