WKen
1
Does DOpus have a RunWait
syntax like the AHK? Or is the default RunWait
RunWait es " " arg " -export-txt " A_Temp "\es-output.txt", , "Hide"
var cmd = DOpus.Create.Command();
cmd.addline("@runmode:hide")
cmd.addline('C:\\Program Files\\Everything\\es.exe -dm -size -full-path-and-name -sort-date-modified test -export-txt D:\\test.txt')
cmd.run
Leo
2
If you just need to wait for the program to finish, add @sync:
at the start of the line that runs it.
You're also missing quotes around the es.exe path, since it contains spaces:
cmd.addline('@sync:"C:\\Program Files\\Everything\\es.exe" -dm ...etc...')
If you also need the program's exit code, the WScript.Shell
Run
or Exec
methods can get it:
WKen
3
I got an error when I tried WScript.Shell
I use DOpus.Output() to output.
Leo
4
You haven't shown us how you're using it, so I can only guess, but it looks like you haven't created the object properly.
Did you look at the examples in the other thread?
WKen
5
Forget it. I'm just a rookie.
