Hello,
So I just upgraded from Directory Opus 12 to 13. I was able to transfer how my 12 worked to 13, except i had to select in menus to hover to select. that did not transfer.
But I cannot figure out how to make SHIFT DELETE from the keyboards to delete selected files again. It worked in my directory opus 12 version but now nothing happens. I searched settings - preferences but cannot find anything. I was able to make a button for DELETE NORECYCLE and can use that by clicking on it. But is it possible to get keyboard working again to pass shift delete to opus to it deles files without recycle bin? I searched for delete in settings preferences and for keyboard but nothing intuitive comes up. It still works in windows explorer. Windows 11 latest. Directory Opus is running in total replacement mode. Keyboard SHIFT Delete keypress is completely ignored.
Also if i hold down shift, and click on file to bring up context menu and select delete, it does permanently delete. It just wont register keyboard delete it seems. but the key is not bad because it is registered in windows , the delete key.
Thank you in advance
