How would I remove the top/bottom padding from the Location subelement of the path bar? The tiny blue lines at the top and bottom of the images, but also whitespace within the Location text itself. Basically I'd like to make the font bigger without making the bar's height bigger, and there is plenty of space for that, it's just a way to be able to use it..,
I right-clicked on the location element in the UI Edit mode and saw a size option, thought that setting everything to 0 would help driveroot,hidedesktopfolders,hidefavorites,size=0+0+0+0+0 (was 0+0+0+3+3 before) but it didn't
Is there another way?
For the left/right pads, yes, it's a couple of pixels, not ideal, but not that big of a deal
But the vertical padding is a different thing - it wastes way too high a % of the total height on emptiness. Would be much better if I could make the text bigger/more readable without any downsides like making the whole bar bigger. Like, the Favorites or the folder icons are bigger than the text even though it'd be legible even it it were twice as smaller and anyway much less improtant than the text!
