Per-folder custom font size + column auto-sizing issue
When a larger than the standard font size is specified for a specific folder (via Folder Formats), and the column auto-sizing option is also enabled, upon entering the folder for the first time, DOpus resizes the columns based on the standard font size, and then updates the font size to the larger value, resulting in the columns being too narrow. When I then click F5 to refresh the window, the columns are sized correctly (to accommodate the larger font size).
It would be great if the developers could fix this, so as to bring DOpus even closer to absolute perfection! Many thanks.
Thanks! Fixed in the next update.
This is to confirm that the bug has now been fixed in the new version that was just released (Version 13.8 x64).
Many thanks to Jon and the DOpus development team for the excellent technical support, and for creating such an awesome file management tool.
